Author Topic: Distributer Drive Gear  (Read 1092 times)
Offline shovel80
« on: November 18, 2007, 09:55:19 AM »
OK i have taken it out of my old block (I used the pencil trick and it worked fine). And now I need to get it into my new Block,what is the procedure to get it back in or is it self aligning ??
Thanks Dave
« Reply #1 on: November 18, 2007, 12:58:04 PM »
Pretty straight forward. Make sure the motor is TDC #1 firing , two shims , then just imagin where the dist. and drive(they fit together only one way) must go while set at #1, allow for some clockwize rotation as it drops in , and drop the drive in.
(then don't turn the motor without a dist. in)
