Author Topic: Weld On An Fittings  (Read 1604 times)
Weld On An Fittings
« on: August 08, 2007, 02:54:51 PM »
Anyone know where to buy steel weld on -6 AN fittings locally. I saw that fuel line article in HotVW's and thought I might try it. Looks clean.
This is what I'm looking for. http://www.anplumbing.com/shop/images/967104.jpg
Jeremy
« Last Edit: August 08, 2007, 02:58:22 PM by brodie »
Weld On An Fittings
« Reply #1 on: August 08, 2007, 03:00:12 PM »
ACVW.net can get them for you or if you want to spend a bit more goto Mopac or Lordco.
Weld On An Fittings
« Reply #2 on: August 08, 2007, 03:20:57 PM »
Tried Lordco. I told them what I was looking for and they just stared at me blankly. Then I said it was for my VW and they immediatly said they don't have anything for VW's. :wacko: I tried again to explain it wasn't VW specific but didn't get anywhere. I'll try Chris at ACVW.net. Thanks James.
Jeremy
Offline Lanny
Weld On An Fittings
« Reply #3 on: August 10, 2007, 06:35:12 AM »
Any hydraulic supply house will have male  JIC to JIC or JIC to NPT adapters. Cut off one end, voila, weld on steel AN bungs.
Weld On An Fittings
« Reply #4 on: August 10, 2007, 06:51:20 PM »
You said bungs!
Weld On An Fittings
« Reply #5 on: August 11, 2007, 09:25:03 AM »
Thanks Lanny. I never thought to try there. Just so I know what to ask for what does \"JIC\" stand for?
Jeremy
Weld On An Fittings
« Reply #6 on: August 11, 2007, 09:43:02 AM »
princess auto has a small selection as well (of the steel ones anyways)
Weld On An Fittings
« Reply #7 on: August 11, 2007, 12:17:27 PM »
I'm heading there right now.
Offline amishrabbi
Weld On An Fittings
« Reply #8 on: August 11, 2007, 01:05:26 PM »
Thanks Lanny. I never thought to try there. Just so I know what to ask for what does "JIC" stand for?
Jeremy
i think it just means steel fitting, -8 an just means you need a female fitting in size 8 army navy
1963 Beetle, 2017cc Stroker
Weld On An Fittings
« Reply #9 on: August 11, 2007, 03:12:37 PM »
P/A had what I was looking for. Only $1.50 a fitting. Just need to cut off one side.  I bought a roll of 5/16 od fuel line from Coquitlam Auto. I will have to drill out the fitting to fit but I figured that was better than the loose fit of 1/4 line. Thanks guys. I'm going to try this right now. I'll take some picks if it works out. As for Army and Navy I only go there on the annual shoe sale. Got some great pumps for $3 this year.
Jeremy
« Last Edit: August 11, 2007, 03:16:45 PM by brodie »
