Author Topic: Clutch Noise  (Read 5616 times)
Offline dirtydeedss
Clutch Noise
« on: July 15, 2007, 09:32:12 PM »
When i press my clutch pedal i can hear a almost grinding noise.  Was wondering if anyone has heard this before, im thinking its the throwout bearing. and when I have the pedal pushed in The lever on the tranny starts to mildly shake.  was just wondering if anyone might know what it is before I go tearing it all apart.
derek
« Last Edit: July 15, 2007, 09:39:12 PM by dirtydeedss »
Offline dirtydeedss
Clutch Noise
« Reply #1 on: July 15, 2007, 09:57:10 PM »
And forgot to mention, I didnt put and grease or oil in or on the bearing, should I have?
Clutch Noise
« Reply #2 on: July 15, 2007, 10:17:30 PM »
Definiteley sounds like the bearing is bad, could have popped off one of the fingers on the release lever too.
The bearings are sealed and can't be greased.
Clutch Noise
« Reply #3 on: July 15, 2007, 11:45:58 PM »
ditto to what busdaddy said.
a little high temp grease on the shaft the throwout bearing rides on could help a bit. and safety wire the clips that hold the bearing to the fork.
Offline dirtydeedss
Clutch Noise
« Reply #4 on: July 16, 2007, 08:29:46 AM »
thanks guys
Offline dirtydeedss
Clutch Noise
« Reply #5 on: July 16, 2007, 11:29:21 PM »
i replaced the bearing and the noise went away. buut the bearing feels new . could it maybe fell smooth when not under load?
Clutch Noise
« Reply #6 on: July 17, 2007, 08:05:38 AM »
It could happen, how were the release shaft bushings? Contacting the pressure plate crooked could cause that too.
Offline dirtydeedss
Clutch Noise
« Reply #7 on: July 17, 2007, 08:14:05 AM »
they seemed fine the shaft didnt have any movement
