Author Topic: Generator Output Voltage  (Read 4134 times)
Offline blarneyman
« on: June 25, 2007, 09:39:20 PM »
I recently bought a 1970 Ghia that had some electrical issues. I replaced the voltage regulator (with a used one) and the generator (used as well). There was a short in the wiring for the tach (disconnected right now).
Question:
What should the output voltage be on the generator at an idle? With all the lights on, it's about 13.5v at idle or reving the engine. If I turn off the lights it goes up to around 14.5v at idle and over 15v reving. This seems to be high to me but I've never measured it before.
www.mbvv.org
My \"new\" 1970 Ghia
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
« Reply #1 on: June 26, 2007, 11:01:00 AM »
The mean (average) regulating voltage for most 12V VW generators is 14V at 2000 rpm, with a cut-in speed of 1450 rpm.
I should have mentioned this when I gave you the generator, but everything you ever wanted to know (and more) on testing and servicing it is on my website:
http://www.type-14.com/Fiche/1-2%20-%20Generator.pdf
« Last Edit: June 26, 2007, 11:04:36 AM by jason_hamilton »
Jason Hamilton
Offline blarneyman
« Reply #2 on: June 27, 2007, 06:17:28 AM »
thanks Jason, that will be very helpful :rockon:
www.mbvv.org
