Author Topic: Help With Choke  (Read 4787 times)
Offline krichards
  • Junior Member
Help With Choke
« on: January 27, 2007, 10:26:27 AM »
81 Diesel, I pull the choke cable, it moves the lever on the injection pump, but nothing changes. It always starts but runs rough untill it warms up a little (2min).
Ideas?
Thanx
Offline Rob DVKK
Help With Choke
« Reply #1 on: January 27, 2007, 11:18:52 AM »
Bad glow plugs?
Help With Choke
« Reply #2 on: January 27, 2007, 12:33:34 PM »
Not DVKK but it's either glow plugs or a leak in something that's letting some air in and it takes 2 min. for the air to purge itself.
Offline 68IIIbuggy
Help With Choke
« Reply #3 on: January 27, 2007, 03:07:58 PM »
I second this. There's not really anything that can go wrong with the rack advance system. Also, check for leaks in your injector pump. The new ULSD (ultra low sulphur diesel) is causing leaks. I just had to replace the seals on my injector pump, as it was leaking from the rack advance lever shaft.
Help With Choke
« Reply #4 on: January 28, 2007, 09:57:16 AM »
Check your base timing of the pump. If it's so far out, the manual advance will do very little to help.
Offline 68IIIbuggy
Help With Choke
« Reply #5 on: January 28, 2007, 06:01:23 PM »
If it's that far out, it won't run either, even when warmed up.
