Author Topic: Powdercoating/sandblasting  (Read 2947 times)
Offline AirCooledRules
« on: January 27, 2004, 10:08:58 PM »
whats the going rate to have a pan sandblasted and powdercoated ... (the pan is in great shape)
no rust/holes. if there are dents i will fix them.
also where do you guys have this done ?. does anyone have a sandblaster and do this on the side ?. or is the pan to thin for sand ?
thanks in advance for the advice.
1960 Volkswagen Beetle
1975 Honda CB125S
1983 Audi UR-Quattro
1984 Volkswagen Rabbit GTI
1998 Audi A6
« Reply #1 on: January 28, 2004, 01:18:51 AM »
airstrip in richmond does sandblasting. they do vw's so they know about the thickness (or lack of) a vw pan. if there is no rust on the pan, a walnut shell blast should clean it up really nice. they will probably want to give it a quick sand blast to give the metal a good \"tooth\" so the primer or paint will take to it. not sure about prices. i would guess $200 - $500. call them. 604-270-7665. talk to jerry. he's the man in charge.
i'm pretty sure someone on here pwder coats. r. scott or pointblank? i'm not sure. hopefully they'll chime in.
« Reply #2 on: January 28, 2004, 06:57:15 AM »
i can powdercoat it for you but it has to come blasted to me.
you can call me at work 888-3712 (ask for russ)
it will run about $200-$250
russ
« Reply #3 on: January 28, 2004, 11:39:59 AM »
bump because I wanted to know this too!
I believe that walnut blasting is fairly inexpensive.
Stephan
« Reply #4 on: January 28, 2004, 01:15:10 PM »
sounds good . its nice to get a ballpark.
i know por-15 is a good product, but is it as good as powdercoating ?
to por the pan will be cheaper but once you really calculate everything its not much of a difference.
i know poweder coating is heavy duty and very long lasting and its probably the route im going to take.
any thoughts?
1975 Honda CB125S
1998 Audi A6
Offline Raymond
« Reply #5 on: January 28, 2004, 07:04:38 PM »
There's a shop out in Abbotsford just off Mt. Lehman.  They are equipped to do pretty big jobs.  I dropped off a couple of wheels and they cleaned them up for me.  Wasn't going to take any money because all the original powdercoating didn't come off but I was more than happy with the results.  Had to force money on the dude so that tells you they are not in it to suck $$$ out of you.  BTW, my buggy wheels turned out great shot with white IMRON 5000 at my work.
We talked about powdercoating.  I mentioned I had two sets of wheels done plus some nerf bars some 10-15 years back and I wasn't impressed with the adhesion.  He explained to me that there are different powdercoating processes depending on the intended use and the materials have also evolved considerably over the years.  Today's products are even tougher and they powdercoat industrial equipment with the stuff.
Lonestar Custom Sand Blast & Paint Inc.
31053 Peardonville Road 8, Abbotsford, BC V2T6K4
(604) 852-2747
« Reply #6 on: February 09, 2004, 06:48:20 PM »
Just a follow up.....Lonestar ain't there anymore. The new Name is Mr. Sandman. I stopped in and talked to Troy last week and he said he would do a pan for me for about 125-150 depending on how much undercoat is on it, he said it would probably take about an hour.
I then called a couple of D.I.Y. blasters, the place on Langley bypass only does small stuff 4x5 was the biggest, at a cost of $50 an hour. There is also a place in South Langley called Canadian Auto Restorations, they set you up outside and let you blast to your hearts content, at a cost of $45 an hour.
Turns out it takes a bit longer then an hour for someone that has never done it before. It took me 3 hours to do the pan and two late bus bumpers, at a cost of $135 cash.
I think next go around for me I will have Mr.Sandman do it, about the same in dollar value but actually doing the blasting kinda sucks!
« Reply #7 on: February 09, 2004, 07:05:17 PM »
Tell me about it!
Offline horizontallyopposed
« Reply #8 on: February 10, 2004, 06:49:21 AM »
any thoughts?
If you're going to go to the trouble of sand blasting a pan, just get it powdercoated and skip the POR 15.  POR 15 is great if you just want to paint over the rust and crap that's already there, but it will never look as nice as powdercoating.  I was just in at Concept-1 as Ken had just returned from the powdercoaters and I was flabbergasted at the colours you can get.  Bass boat metal flake purple was my fave.   :lol:
I tried to find a picture of my pan once the POR 15 was done, but I'll have to check at home.
-Keith
Club Vee Dub | My Resto (updated every blue moon)
calgary.ab.ca
66 Beetle | 59 Euro Beetle | 86 Westy | 04 Passat
I gotta have more cowbell!
« Reply #9 on: February 10, 2004, 06:55:45 AM »
click my homepage,if you want to see a powdercoated pan(i did not go with black)
« Reply #10 on: February 11, 2004, 02:13:16 AM »
Russ, That colour looks great.  I may just go for something subtle like that instead of black
I can't believe that guy is blowing the powder on bare handed!  I guess he hasn't been shocked bad enough.  (that's not you is it?)
« Reply #11 on: February 11, 2004, 08:20:57 AM »
 :rockon:  :rockon:
I love that Colour too.  Silver pan!
Stephan
« Reply #12 on: February 12, 2004, 11:45:27 AM »
sweetness ... thanks for the great info.
i should really get cracking on this project, its so hard to get the ball rolling when you own 3 vws and your 18  ]:(
1975 Honda CB125S
1998 Audi A6
