Author Topic: Swing To Irs?  (Read 4190 times)
Swing To Irs?
« on: November 01, 2006, 06:29:51 AM »
I remember once changing a trany in just ove an hour on a 1971. It looks like swing is a lot more complicated.
What again is the process of changing swing to IRS?
Swing To Irs?
« Reply #1 on: November 01, 2006, 04:46:29 PM »
It's a bit of a process. I did it to my '59 but I have the body and pan seperated. Much easier this way. You must weld in trailing arm brackets and dimple the frame horns to clear the cv joints. There is also and issue with trailing arm/shock tower clearance. Track down some the necessary irs parts. (Trailing arms, axles, cv's,springplates) I found a irs rear end with all that stuff for $50. Brackets are $20ish. Then find a tranny.
Jeremy
Swing To Irs?
« Reply #2 on: November 01, 2006, 04:49:22 PM »
Double post.
« Last Edit: November 01, 2006, 04:50:39 PM by brodie »
Offline shovel80
Swing To Irs?
« Reply #3 on: November 01, 2006, 11:18:14 PM »
Have been working on mine for some time now Got the irs bolted in and ready to go
Used the alignment jig from airspeed (don't know the status of that nice peice of equimpent) Made a world of differance in the setup of the pivot brackets. You will need new torsion bars and spring plates, end caps
e brake cables possibly new style clutch
oh ya and some more PATIENCE
Dave
Swing To Irs?
« Reply #4 on: November 02, 2006, 06:10:19 AM »
Dave
Patience is a virtue that you can't buy.
Did you take any pictures?
Swing To Irs?
« Reply #5 on: November 02, 2006, 01:35:31 PM »
If you want all the parts at once, contact Mirko.  He took off everything you need when he went the other way.
