Author Topic: Cleaning A Case  (Read 9539 times)
Cleaning A Case
« on: July 13, 2003, 09:14:50 PM »
hey guys,
whats the best way to clean a freshly machined and clearenced case?
im going to pull the plugs out to get into all the corners, and use solvent and compressed air, any other tips and tricks? -dan
Cleaning A Case
« Reply #1 on: July 13, 2003, 09:54:34 PM »
Take it to Royal oak car wash and when there is no one around use the pressure washer to spray out all journals.  Get every passage ,nook and cranny and that should be good.
Cleaning A Case
« Reply #2 on: July 13, 2003, 10:59:48 PM »
Hey Dan,
I had a look for AL hex bar but only could come up with steel sorry. I have access to an industial parts washer at work, might clean that case up nice... Lemme know and I can give it a try for you.
Cleaning A Case
« Reply #3 on: July 14, 2003, 06:04:46 PM »
cool, thanks for looking for the hex james, and thanks for the help -dan
Offline moni
Cleaning A Case
« Reply #4 on: July 21, 2003, 05:09:00 PM »
i just finished scrubbing my case last week, and highly recommend brakekleen for serious gunk, a power wash and a lot of elbow grease.  i've also heard a quick wash with mild detergent prolongs case life.
have fun scrubbin'  :P
Offline Raymond
Cleaning A Case
« Reply #5 on: August 01, 2003, 07:13:45 AM »
If you don't have access to a parts washer, then pick up a few cans of Brake Kleen.  Its a good solvent and relatively cheap compared to carb cleaners and the like.
To clean the passages, nothing works better than bronze-phospher brushes for cleaning gun barrels and an old cleaning rod.  You'll need a few different sizes and there only a few bucks at a sporting goods store.  Shoot a blast of cleaner into the passage and work the brush back and forth 6-8 times.  Flush with solvent and shine a light into the passage.  If your not sure its clean, rinse the brush and repeat.  When you pull the brush out, see if its still getting dirty with crud.  It's a good indication how clean its getting.
I just did what I thought was a pretty clean crank.  The cross-drilled passages contained a fair bit of \"mud\".   I was amazed that much crap builds up in there.
