Author Topic: B/j Front End Vs Super Front End  (Read 3595 times)
« on: October 23, 2006, 11:02:25 PM »
If you had a 71 or later VW Super chassis, could you changed the front end to B/J and use it on a 66 or later Beetle?
« Last Edit: October 23, 2006, 11:03:17 PM by egspot »
« Reply #1 on: October 23, 2006, 11:19:39 PM »
super beetle? super beetles use struts and are not interchangeable with your 66's front end.
Offline dods1600
« Reply #2 on: October 23, 2006, 11:55:51 PM »
The pan even has a different shape to it, so the only thing that is the same is where te engine bolts to.
I drive a fat chick
-Tristan
« Reply #3 on: October 24, 2006, 03:59:35 AM »
It can be done, but is a ton of work.  What you'd have to do is cut the frame head off and weld on a torsion bar frame head.  From the bulkhead where the master cylinder bolts on, rearwards, the std Beetle pan and the Super pan are identical.
I have a friend in CA that did this.  He took a 72 Super pan, hacked off the frame head, welded on the torsion bar frame head, then put his 69 body on it.
« Reply #4 on: October 24, 2006, 07:55:44 AM »
I am glad I asked. WOW!
