Author Topic: What Did I Find?  (Read 1321 times)
Offline 62bugg
What Did I Find?
« on: October 18, 2006, 06:27:52 PM »
I found an old motor with all its original german gear and tags on it. The fan shround had a tag that had a tag that said Volkswerks and then it said Type 126 and Motor 080144, it had a solex carb VBIS and some other strange parts that seemed to be attched to the carb, only thing missing appeared to be the generator. I didnt have my camera though. If you have any ideas let me know. It had all its original tin on it too. Oh yea single tip exhaust but i ran out or room to right all the info down off the stock muffler.
Cheers
ROb C
What Did I Find?
« Reply #1 on: October 18, 2006, 10:08:43 PM »
Kinda sounds like an industrial motor, was the tin square at the  pulley end? as in flat across the back with square corners, not curved. May also have an odd flywheel with the starter teeth facing the front, not around the outside.
