Author Topic: Generators  (Read 5343 times)
Offline epic3
Generators
« on: October 15, 2006, 10:21:22 PM »
what kinda current do they put out
I`ve got four 55 watt drivin lamps on my buggy and the genny doesn`t seem to keep up when runnin them and the battery voltage gets down
Generators
« Reply #1 on: October 16, 2006, 11:10:48 PM »
A \"generator\"(not alternator)  is rated at 30 amps , so I think it works like this..... 30 amps x 12 volts = 360 watts( if it's working perfectly)
your four 55 watt lights = 220 watts  plus anything else you have on..... wipers , stereo , ignition , stock head lights and running lights etc etc
 You could be close to the edge.
I'm not 100% sure this the correct calculation , someone correct me if I'm wrong.
Offline epic3
Generators
« Reply #2 on: October 17, 2006, 01:35:10 PM »
well all I'm running is the four lights and the ignition had a stereo  in there but taken out so yeah if you are right and my genny is gettin weak then thats why my battery gets weak when runnin the lights thanks
Offline Mowser
Generators
« Reply #3 on: October 17, 2006, 09:53:43 PM »
Your calculations are correct.  Keep in mind that most likely the \"30A\" rating on the gen is Peak output.  That would be flat out going hard.  Now you slow down and the rev's go down... you won't be getting Max rating anymore.
Generators
« Reply #4 on: October 18, 2006, 04:44:45 PM »
time to pick up an alternator from airspeed while you still can...
Offline epic3
Generators
« Reply #5 on: October 19, 2006, 09:11:24 PM »
I`ll hold off on the alt convertion for now cus if my bus don`t sell before to long the 2000 is comin out of it and goin in the buggy and it`s alt
