Author Topic: What Could Be These Symptoms?  (Read 7104 times)
« on: October 07, 2006, 04:32:14 PM »
OK so the engine starts and while there is another motor on the works, I want to find a way with the current engine. The engine starts and idles fine. There is good strong presure comming out of the tail pipe until I rev it. I do not know why the forced hot air drops substantially.
Any ideas?
« Reply #1 on: October 07, 2006, 06:30:41 PM »
Not DVKK but....
Does it have a DVDA distributor? That'll make for strong exhaust pressure at idle and much less when you open the throttle. Don't worry about it.
« Reply #2 on: October 07, 2006, 09:26:40 PM »
Not DVKK but....
NO, I mean much , much less presure out of the tail pipe.
« Reply #3 on: October 07, 2006, 10:21:07 PM »
Try another muffler.
« Reply #4 on: October 08, 2006, 10:16:59 PM »
Don't know who you are.
Thanks anyway.
« Reply #5 on: October 11, 2006, 01:57:59 PM »
Not DVKK but....................................its a diffuser valve!
Try a supercharger or another forced induction system! :P
« Reply #6 on: October 11, 2006, 02:36:00 PM »
diffuser valve wtf are you on? its got to be the inflection controller, and the only way to fix that is to rewire the distributor
« Reply #7 on: October 11, 2006, 03:17:03 PM »
Are U all  having fun with this?
« Reply #8 on: October 11, 2006, 06:10:46 PM »
major exhaust leak somewhere? heads, header, muffler, flanges?
« Reply #9 on: October 11, 2006, 07:32:08 PM »
are you not having fun with all this?
« Reply #10 on: October 11, 2006, 09:27:24 PM »
NOT DVKK........Yes I am! :D
« Last Edit: October 11, 2006, 09:27:44 PM by steveo_32 »
Offline moodyman
  • 1988 Vanagon w/2.2 Turbo Subaru power........
« Reply #11 on: October 11, 2006, 11:57:56 PM »
My DC had the same issue. After hours of diagnostic tests I found it to be a faulty rectal diverter valve.
Put some fun between your legs, ride a mountain bike.
« Reply #12 on: October 12, 2006, 12:12:50 AM »
never even thought about that, an easy fix for that is rear end lube job.
