Author Topic: How To Compare Tires?  (Read 6759 times)
« on: October 06, 2006, 11:28:46 AM »
What would be the same as 165R15?
165 60 15 would be 165 wide 60 hight 15 tim?
Offline Chris W
  • Portland Oregon
« Reply #1 on: October 06, 2006, 11:45:45 AM »
Offline 68IIIbuggy
« Reply #2 on: October 06, 2006, 11:48:26 AM »
A 165r15 is considered an 80 series tire. ie 165 80r 15.
« Reply #3 on: October 06, 2006, 12:10:05 PM »
Wow!
I was way off. I am trying to match the original diameter or better. I think I got 175 70 15 currently. I wanted to get something just a bit larger and wider.
Offline 68IIIbuggy
« Reply #4 on: October 06, 2006, 12:27:09 PM »
A stock Vw tire is about 25.5 inches in diameter.
« Reply #5 on: October 06, 2006, 08:04:20 PM »
Wow!
175/70/15 = 24.64\"s high
165/80/15 = 25.39\"s high
165mm (the tread width, the area that contacts the road)
80% (the aspect ratio, or sidewall. 80% of 165mm is the sidewall height. then you multiply that # by 2 and add the diameter of the rim to get the total height of the rim & tire combo)
15\" (the rim diameter)
so...
165/80/15 is...
165mm tread width
80% of 165mm = 132mm x 2 = 264mm
divide 264mm by 25.4 (25.4mm = 1\") to get inches = 10.39\"s
add 15\"s of rim diameter to get total rim & tire height of 25.39\"s
all this can be done with a simple calculator or you can play with the link that chris posted.
205/65/15 = 25.49\"s high. very close to the height of a stock rim & tire. but...a 205 is wider than a stock setup by 1.57\"s.
hope that wasnt too confusing. it makes sense to me but i have difficulty explaining things sometimes.  ;)
good luck with the tire search emilio.
« Reply #6 on: October 06, 2006, 09:04:30 PM »
Wow!
175/70/15 = 24.64"s high
165/80/15 = 25.39"s high
15" (the rim diameter)
so...
165/80/15 is...
165mm tread width
divide 264mm by 25.4 (25.4mm = 1") to get inches = 10.39"s
add 15"s of rim diameter to get total rim & tire height of 25.39"s
205/65/15 = 25.49"s high. very close to the height of a stock rim & tire. but...a 205 is wider than a stock setup by 1.57"s.
Thanks Silas, That was a perfect explanation..
