Author Topic: Any Right Hand Ovals Around?  (Read 1546 times)
« on: September 27, 2006, 04:29:21 PM »
i have had alot of people looking for cruiser pedals to fit right hand drive cars.
the way they are made right now it just won't work,i think if the pivot arm had a flat plate attatched to it,i could bolt it through the pan.
so i guess i am curious if anybody has a right hand drive car locally with a roller pedal (stock one)
i would just like to look at it to see if i can make a pedal work for it
thanks russ
« Last Edit: September 27, 2006, 05:13:48 PM by Russ »
Offline Aubergine_Neil
« Reply #1 on: September 27, 2006, 04:44:40 PM »
you could try and ask on volkszone.com. Its a UK based VW forum. Its generally full of dickheads but the technical side is pretty good.
Might get some pictures as I just realised you said locally!
« Last Edit: September 27, 2006, 05:02:45 PM by Aubergine_Neil »
1983 Special Edition \"Aubergine\" Mexican Bug.
« Reply #2 on: September 27, 2006, 07:27:17 PM »
thanks russ
que (from the us, franklins forum) has one. maybe with enough detailed pics you can get an idea of what needs to be done.
Offline doubledoor
« Reply #3 on: September 28, 2006, 05:00:04 PM »
Russ I have a set for my car if you need to look at them :D
49 ford coupe
« Reply #4 on: September 28, 2006, 06:26:48 PM »
that sounds great,i will get ahold of you when i get back from Hawaii
i just need to see how it mounts to the pan and what i can make work.
thanks appriciate it
russ
Offline Que
« Reply #5 on: October 01, 2006, 06:12:14 PM »
If you need some pics let me know, i can snap a few.
Que
\"Hey, I'm Canadian and we Hug\"
'56 RHD Oval Bug - Sold
'64 2.6L T4 Bug - Finally Back on the Road
« Reply #6 on: October 01, 2006, 08:12:31 PM »
Que,
if you could snap a few it might give me a better idea on what needs to be done before i try and mock something up
thanks russ
