Author Topic: Screwed Up...  (Read 1786 times)
Screwed Up...
« on: September 21, 2006, 11:31:09 PM »
found in the gallery on thesamba.com
Screwed Up...
« Reply #1 on: September 21, 2006, 11:54:14 PM »
I wondered where those tin screws went
Screwed Up...
« Reply #2 on: September 21, 2006, 11:57:28 PM »
the ones you threw in shanes turbo before he went to sac? :o
« Last Edit: September 21, 2006, 11:58:29 PM by silas »
Screwed Up...
« Reply #3 on: September 22, 2006, 12:12:23 AM »
no those went it to James, but his cuisinart needed no help to fail!
Offline AlanU
Screwed Up...
« Reply #4 on: September 22, 2006, 07:37:36 AM »
kadron screws from the throttle plate. That truly sucks
Offline Tom H.
Screwed Up...
« Reply #5 on: September 22, 2006, 09:35:11 AM »
I have a similar one at home. A throttle shaft/butterfly screw out of one of my throttle bodies.
 :rolleyes:
loctite is a friend
 :rockon:
« Last Edit: September 22, 2006, 09:35:29 AM by Tom H. »
Offline GMB
Screwed Up...
« Reply #6 on: September 22, 2006, 12:32:00 PM »
At least he knows EXACTLY what was making the \"noise\"
   Gary.
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
Offline shortseurocustom
Screwed Up...
« Reply #7 on: September 26, 2006, 09:35:22 PM »
I'd like to order a screwdriver, heck- make it a double.
If you want it bad, you'll get it bad- The worse you want it the worse it will be!
