Author Topic: Fs: Jvc Kd-sh9750c Cd Player - $400  (Read 2953 times)
« on: January 20, 2004, 01:33:32 PM »
the deck was used in my jetta for 2 days. the car was sold right after that, and I haven't used the deck since. the remote, case, owners manual are all still in the original wrapping. I have everything and the box for this deck.
some specs of the deck:
The JVC KD-SH9750 is part of the aggressive Arsenal lineup, with impressive features designed to turn audio into entertainment. This player is compatible with CD, CD-R, and CD-RW, and it can play MP3 or WMA from disc. The KD-SH9750 doesn't mind if you put WMA and MP3 files on the same disc. It will display ID3 version 2 information, along with CD Text.
The KD-SH9750 uses an impressive DSP chip that provides a seven-band equalizer along with a variety of sound field modes. This is a Digifine2.3 model with enhanced digital converters and a high-end tuner that hones in on the desired station. The unit has changer controls with an adjustable line input and a strong 4-volt line output to drive an external amp.
Internally, it has a MOS-FET amplifier with a maximum output of 50 watts into four channels. It uses gold-plated terminals, which include a subwoofer output with independent level and frequency control.
The motorized faceplate has adjustable tilt angles, and it can be removed for security. It comes with a wireless remote control. The KD-SH9750 features JVC's PICT technology, which will load images from a CD-R that you create to use as the display background. It can be 15 seconds of animation, and up to 90 still images that will display as a mobile slide show. Without that, it's an attractive system, but with PICT, it's as good-looking as you make it.
Power Output: 200W Max. (50W x 4)
MOS-FET Power Amp
Motorized Slide-Out Aluminum Face
Personalized Image Capture Technology (PICT)
MP3/WMA/CD-R/CD-RW Compatible
Customize the head unit's display with free images and animations from JVC
7-Band iEQ
Gold-Plated Line Output Terminals (2 pairs)
Subwoofer Output Terminals with Level/Frequency Control
4 Volt Line Output Level
Multi-bit (24-bit Resolution) 1-bit DAC
Adjustable Line Input
HS-IIIi Tuner
Station Name Registration
Rotary Encoder Multi-Control
Multi-Function Wireless Remote Control
3D Graphics Display with Contrast Control
Switchable Dimmer
Detachable Control Panel with Carrying Case
CD Text, Disc Name Registration
CD Changer Control with Disc Name Registration, Random/Repeat Play (2 Modes), Intro Scan (2 Modes)
CD Player Intro Scan
CD Random and Repeat Play modes
Direct Track Access (1-12)
Direct Disc Select (1-12)
18 FM & 6 AM Presets
SSM (for FM)
AFNS/PNC
COMPU PLAY
Electronic Volume Control
Preamp Fader Control
$350
604-431-5454
Stephan
« Last Edit: January 22, 2004, 12:56:10 PM by Stephan Schmidt »
« Reply #1 on: January 20, 2004, 03:41:40 PM »
wow great ad ..... You should apply for a job at Airspeed selling... ;)
What is it worth new???
have any beetle parts?
« Reply #2 on: January 20, 2004, 11:13:07 PM »
hey shane, I have the receipt (I got a good deal on the deck with install etc) and it came to $530 or so.
let me know.  I don't have any beetle parts right now
stephan
« Reply #3 on: January 29, 2004, 10:27:37 AM »
bump!
1 year warrentee with the deck!
Stephan
