Author Topic: 009 Advance Springs  (Read 5237 times)
Offline notorious B.U.G.
009 Advance Springs
« on: September 06, 2006, 06:44:54 PM »
I just got an old german Bosch 009 distributor. When I cleaned it up and could see inside the body, it turns out there is only one advance spring inside? It looks like there is a matching spring post, 180 deg from the one spring. Is it okay to use this distributor to get my engine started? Is that some kinda performance mod, removing a spring? or do they only come with one spring?
Anyone know or have a link that shows a cut-away of a 009? and how to remove the plate that the points bolt to?
TIA
Chris B
« Last Edit: September 06, 2006, 06:46:26 PM by notorious B.U.G. »
56 Patina Sedan
009 Advance Springs
« Reply #1 on: September 06, 2006, 07:18:24 PM »
Okay, I figured out how to remove the plate. here is a pic. So will the advance just come on sooner with one spring? I assume it will run poorly? Correct?
Chris B
56 Patina Sedan
Offline Tom H.
009 Advance Springs
« Reply #2 on: September 06, 2006, 07:50:37 PM »
they only come with one spring.
009 Advance Springs
« Reply #3 on: September 06, 2006, 10:22:53 PM »
Quote from: Tom H.,Sep 6 2006, 06:50 PM
Thanks Tom. Are you sure though? Because opposite the existing spring, there is exactly the same post and plastic retaining sleeve/clip thingy that is grooved to hold a spring? :unsure:
Chris B
56 Patina Sedan
009 Advance Springs
« Reply #4 on: September 07, 2006, 03:02:40 AM »
Listen to Tom.  All 009s came with only one spring.  Other spec Bosch distributors used 2 springs, like stock VW distributors.
009 Advance Springs
« Reply #5 on: September 07, 2006, 09:20:30 PM »
Thank you Master Bruce! While I didn't doubt Master Tom's response I guess I just wanted a second opinion just in case. :P
Thanks to both of you,
Chris B
56 Patina Sedan
