Author Topic: Help Fix My Parents Driveway!  (Read 2160 times)
« on: September 04, 2006, 05:29:01 PM »
Hey folks,
Finally have gotten my oil leakers/ parts car away from the parental's compound. However now their once former pretty looking driveway is oil stained. Anybody have a idea how to get some of those deeper stains out?
-Kirin
« Reply #1 on: September 04, 2006, 05:58:42 PM »
Laundry detergent and elbow grease, or an industrial cleaner like Citra-Clean.
« Reply #2 on: September 04, 2006, 06:24:16 PM »
trying some citrus cleaner with damp newspaper with a black garbage bag over it.
« Reply #3 on: September 04, 2006, 06:35:04 PM »
urine, and lots of it.
the trace amounts of amonia will burn the oil stains out.
« Reply #4 on: September 04, 2006, 06:37:53 PM »
Silas I have no idea where to find this Urine. Can you help me? I can only steal so many hospital bedpans and catheters by myself.
« Reply #5 on: September 04, 2006, 06:41:23 PM »
no.
if you havent found it yet, you probably never will.
« Reply #6 on: September 04, 2006, 06:45:04 PM »
(whine!)
Now I know why girls don't like me!
(whine!)
 :wacko:  :unsure:
Offline blarneyman
« Reply #7 on: September 04, 2006, 09:50:10 PM »
I take it this is on concrete? Try using some Coke.
www.mbvv.org
My \"new\" 1970 Ghia
« Reply #8 on: September 05, 2006, 08:55:16 AM »
That could get expensive :wacko:
Offline rolls and pleats
« Reply #9 on: September 05, 2006, 09:14:45 AM »
Muriatic acid works on concrete. Your local paint store usually has it.
« Reply #10 on: September 05, 2006, 09:23:01 AM »
At work we use this stuff called \"bold\" very toxic. It is used at the gas pumps when they are filling up the transit buses when there is spillage. All you do is pour some on the ground and use a old broom to mix it in then hose it off.
« Reply #11 on: September 05, 2006, 01:41:57 PM »
you need to sacrifice a virgin and use her blood too clean a vw oil stain.
Offline Mike Scott
« Reply #12 on: September 05, 2006, 02:07:40 PM »
I'll need a boat load of virgins to my place then :lol:
« Reply #13 on: September 05, 2006, 03:28:24 PM »
I AGRREE Muratic acid is what brick layers use to clean blocks etc. Home Depot sells a product a little more enviro friendly called concrete etcher. Use either with caution.
Gary
Offline blarneyman
« Reply #14 on: September 05, 2006, 06:41:45 PM »
I would give the Coke a try before spending a bunch of money on Muratic acid. I used to work at a garage (almost 30 years ago) that's what we used. Soak it down, let it sit for an hour soak it down again and scrub with a stiff broom. Then you can just spray it down the storm drain. No harm done like the acid (at least not much). Well, maybe if the fish go to the dentist :P
www.mbvv.org
Offline Chad M
  • Custom Title
« Reply #15 on: September 05, 2006, 09:11:42 PM »
Three letters, C L R.  That stuff will eat the oil out of asphalt.
Offline dods1600
« Reply #16 on: September 05, 2006, 10:23:51 PM »
This is expensive but gasoline works to get oil stains off of concrete, that's how i cleaned the shop i work in when it was blessed with a VW oil stain.
I drive a fat chick
-Tristan
