Author Topic: Line/loc Adapter Fittings  (Read 11817 times)
Offline Bullyboy
« on: August 27, 2006, 10:59:03 AM »
I'm looking for the adapter fittings to go from the stock metric bubble fitting to the 1/8\"NPT on the hurst roll control.
Been all over town, no luck
« Reply #1 on: August 27, 2006, 12:14:42 PM »
Airspeed stocks them - call on Monday.
Offline Bullyboy
« Reply #2 on: August 27, 2006, 03:27:31 PM »
Thats good, why didn't they tell me when I bought the line/loc last week :huh:
« Reply #3 on: August 27, 2006, 07:16:02 PM »
Some people re flare the ends (Thats what I did on mine) or you can use the adapters. we have lot's in stock.
Offline Cameron
« Reply #4 on: August 28, 2006, 08:10:07 AM »
I'm one of those people, too.
When I installed the line loc, I relaced the brake lines at the same time. I went to the local parts store (Lordco?), and bought a nice mix of SAE and metric lines. Cut one end off, and reflared, so the brake lines have one SAE flare nut, and one metric flare nut.
Hooray! New lines, and no adapters.
« Reply #5 on: August 28, 2006, 10:38:41 AM »
Plus less connections equals less chance of leaks...
Offline Bullyboy
« Reply #6 on: August 28, 2006, 12:29:42 PM »
SAE fitting ends still don't get the job done.
The threads in the solenoid body are NPT  :huh:
Now I have the adapters from NPT-SAE no problem.
Just have to come up with the flaring tool to do the lines.
« Last Edit: August 28, 2006, 05:42:59 PM by Bullyboy »
« Reply #7 on: August 29, 2006, 02:46:01 AM »
I recall the adaptors I installed on Rick's car were M10x1 VW flare to NPT.  Got those adaptors from Airspeed.
Offline DonO
« Reply #8 on: September 27, 2007, 07:28:59 AM »
I took your advice and purchased a metric brake line, cut it to length and double flared the end for an SAE brake fittings.  The Hurst Line-Lok is now plumbed in.
Next step is the wiring.  I have no idea where the button should be installed.  I have an original Hurst shifter in my 1973 convertible.  Please post pictures of where you mounted your roll-control button.  Ideas on how to run the wires through the firewall would also be helpful.
I'm looking forward to burning the rubber off my eight spoke tires, 'cuz I've just bought 4 - 17x7 OEM Boxster turbotwist rims with ZR 40 series tires, and I told myself I need to destroy the 15\" set before I install the 17\" set.
DonO
Re: Line/loc Adapter Fittings
« Reply #9 on: May 28, 2008, 10:05:50 AM »
Hey Don - long time no chat!
Here is a picture of my engagement button, also controls my 2 step as well:
Do you still have your vert? I see that you are in Quesnel now - if so my next trip up lets have a beer!
Offline DonO
« Reply #10 on: June 01, 2008, 09:05:15 AM »
James, thanks for the picture of your setup.  It looks like you have more than just the Line-loc switch on your shifter.  Does that black handle activate the switch, or is it the reverse gear lockout?
Yes, I still love my '73 'vert.  Today I'm changing out the McPherson strut springs for CRX springs on an eccentric cup so that I can fit the new 17" Porsche wheels and rubber under the fenders.  I have just finished painting the four disk brakes and will be installing them as well.  I hope to be burning some of that new rubber off by next weekend.
I bought a new espresso maker from Starbucks, so when you drop by I'll treat you to one (or more) of my famous coffees.
DonO
[attachment deleted by admin]
Offline Hotrodvw1
« Reply #11 on: August 14, 2008, 07:09:18 PM »
I made a fitting that's a female 10mmx1.0 bubble flare X male 1/8" npt.  If I don't carry it at work, I just make it.  I found it easier to convert everything to SAE, rather than fight the metric head ache.
