Technical
Chassis & Suspension Forum
Beetle Ball Joints
Topic: Beetle Ball Joints (Read 3487 times)
kubelguy
The road to success is always under construction
Beetle Ball Joints
August 13, 2006, 08:57:49 PM »
How can you remove a beetle lower ball joint?
Hammering the knuckle does not loosen it.
Somebody's gotta have a tool for this!!!!!!!!
aaaaaaaaaagh!!!!!!!!!!!!!!!!
Last Edit: August 13, 2006, 08:58:10 PM by kubelguy
'68 deluxe bus/sunroof
'57 beetle
James Buchan
Beetle Ball Joints
August 13, 2006, 09:19:27 PM »
If you mean remove it from the arm you need a press, if you mean remove it from the spindle heat and a hammer.
kubelguy
Beetle Ball Joints
August 14, 2006, 11:11:16 AM »
'57 beetle
Bruce
Beetle Ball Joints
August 14, 2006, 08:40:43 PM »
Get your two biggest F'n hammers. place one on the knob of the spindle in front of the BJ, and hit it hard on the rear with the other hammer. Your hammer blows are sandwitching the BJ. Hit it hard enough, it will pop out.
kubelguy
Beetle Ball Joints
September 10, 2006, 07:38:33 PM »
Yep, BFH did it
'57 beetle
Technical
Beetle Ball Joints
