Author Topic: 72 Van Carb Problem  (Read 1083 times)
Offline jess rotten
72 Van Carb Problem
« on: July 23, 2006, 05:54:53 PM »
does anyone know what the little electronic gizmo is on the left hand carb of a 72 van is and where can a guy get a new one. it is a small rectangular box with one wire going to it there is a small brass selinoid and a small ballbearing in it it hooks up to a air vetury in the carb
72 Van Carb Problem
« Reply #1 on: July 23, 2006, 06:10:53 PM »
If the gizmo you are describing is near the top of the carb on the outside with an approx. 2\" long x 1/2\" stamped aluminum plate covering it it's the thermal compensator.  It was a great idea when your bus was new, raised the idle speed and enriched the mixture when it was cold, the solenoid thingy in there is a heater and even if it still works the seals on the bimetal valve are always done for.
Take it off, box and all (two or three screws holding it on), and seal up all the holes with silicone (including the screw holes), for the odd day when it might have helped you can live with warming your bus up 10 more minutes and forget about the hassle it causes with erratic idle mixtures. Don't forget to tape up the wire that went to it.
