Author Topic: Bus Snubbers  (Read 3274 times)
Offline btljuce
Bus Snubbers
« on: July 12, 2006, 09:55:20 PM »
are you guys using bus snubbers for rear suspension ? or are you using urethane bug ones ? also what about using a set of 28mm torsion bars for the rear ?( i believe they are 28mm but i could be wrong )
« Last Edit: July 12, 2006, 10:02:15 PM by btljuce »
Der Kleiner Rennwagens
 56 rag oval now  2332 !!
 56 wolfsburg kombi
Bus Snubbers
« Reply #1 on: July 13, 2006, 09:56:06 AM »
personally i use stock torsion bars, stock shocks and bus snubbers with airspeeds limit straps
im sure it could be dialed in more than that but its an easy proven combo that works...
