Technical
Transmission Forum
Main Shaft
Topic: Main Shaft (Read 5129 times)
kubelguy
The road to success is always under construction
Main Shaft
July 09, 2006, 09:27:46 AM »
the engines out, the bottom of the bell housing is wet and the mainshift is wiggly in the seal.
Can you just replace the sealor is there something wrong inside the transmission?
'68 deluxe bus/sunroof
'57 beetle
Bruce
Main Shaft
July 09, 2006, 11:28:32 AM »
First you have to determine if the oil is from the engine or the trans.
It is normal for the input shaft to be able to wiggle around.
Technical
Transmission Forum
Main Shaft
