Author Topic: Then There Is The Brakes!  (Read 6446 times)
« on: July 04, 2006, 10:01:00 PM »
OK so I minus well look into the Brakes.
1- Can  I install a 1967 dual  (two lines in) master cylinder on my 1966. Do they have separate systems for the front and back?
2- There is another rear drum braking system from a 1969 type 3, I believe (correct me if I am wrong, very likely) The have a wider shoe and provide more breaking power. I understand  that They can be intalled  Back Plate,and all hardware without any modification.
3- what is the story with front disks? I understand that they are very expensive.
« Reply #1 on: July 05, 2006, 06:24:15 PM »
Answer 1:
Yes you just need to figure out how to mount a resevoir for it.
2. I believe so yess.
3. Disc brake kits are 300 bucks but the expenses also should include proper sized tires...
