Author Topic: ...  (Read 10434 times)
« on: June 21, 2006, 11:02:40 PM »
« Reply #1 on: June 21, 2006, 11:12:59 PM »
:rockon:
what compression ratio James?
Stephan
« Reply #2 on: June 21, 2006, 11:19:08 PM »
looking good james.
Offline Matt Davis
    • http://www.mattdavisracing.com
« Reply #3 on: June 21, 2006, 11:21:18 PM »
Is that an AJ system?
Offline Klaatu
    • http://www.airspeedparts.com
« Reply #4 on: June 21, 2006, 11:23:46 PM »
Cool Dude... :rockon:   How did the hoses work out?
I can't reach the bottom but I sure bang the sh*t out of the sides....
« Reply #5 on: June 22, 2006, 12:00:53 AM »
Hoses worked out perfectly - I have a bunch of fittings I ended up not needing but oh-well.
Nope not an AJ system - The carb originally started on one of his systems and the breather box came from him. I pieced this together myself with help from Jim at Airspeed.
Compression is 8:1
After the weekend I will need to go back and redo a few things and fab up a proper exhaust but she is good to go!
« Last Edit: June 22, 2006, 12:01:19 AM by James Buchan »
« Reply #6 on: June 22, 2006, 07:41:46 AM »
Nice job James, How much boost you planning on running?
Offline Pipes
« Reply #7 on: June 22, 2006, 07:45:09 AM »
Wow man! that looks sooo mean!  I need to start planning my Type 4 turbo build  :rockon:
or maybe I should just try to get my NA Type4 even running properly.....  :ph34r:
Trying for low, show & go
1967 Beetle
« Reply #8 on: June 22, 2006, 08:50:03 AM »
Looking good dude! But is it a runner yet?????
« Reply #9 on: June 22, 2006, 09:02:31 AM »
Compression is 8:1
Well James I am glad you have mastered photo shop.... Dood that is gonna be so Loud... and uhmmm how does the decklid fit on?
Offline G-dog
« Reply #10 on: June 22, 2006, 09:05:52 AM »
Awesome ! That'll get you to the golf course lickety split! ;)
« Reply #11 on: June 22, 2006, 10:38:47 AM »
DECKLID - WE DON\"T NEEEEED NO STINKIN' DECKLID!
No time to fab up a mount for it so going without this weekend.
Planning on below 10psi on the street.
Offline Matt Davis
« Reply #12 on: June 22, 2006, 10:46:04 AM »
Looks good James!! :rockon:  :rockon:  Consider water/alky injection. www.coolingmist.com are the systems I use.
One main line in, then T it to each side of the end castings and wallah! Done deal. You can run up to 2 more psi on the street and keeps that intake charge nice and cool and that cumbustion chamber nice and clean for an effeciant burn.
What cam and heads you running??
« Reply #13 on: June 22, 2006, 12:49:41 PM »
stock :lol:  :lol:  :lol:
Offline reefreshd_jive
« Reply #14 on: June 22, 2006, 06:44:57 PM »
it is really not that loud. i think james will post a video after he changes his panties, and stops shaking!
« Reply #15 on: June 22, 2006, 07:53:05 PM »
Yup video footage was taken of the initial startup - not the shakedown lap around the block  :ph34r:  It has a tad bit more pull than it used too!!!!!!!!!!
Matt - Heads are 044's 42x37.5 with a nice P/P job by Pat Downs. Cam is a Pauter custom grind with 1.1:1 rockers :)
I was suprised how quite it was at idle with the shorty pipe, I expected alot louder - but at around 5k HOLY SHIZNET!
James is right, I was a bit shaken when I returned from the lap, had to have a beer pronto to cool the nerves!
« Reply #16 on: June 22, 2006, 09:32:50 PM »
So if you run 10-12 pounds, and I run some  then...... :huh:
Wanna Race?   Looser buys hamburger and fries from the concession at the race track for the winner.
We'll show these guys that you don't need a stroker to have fun.  And hopefully I'll prove you can get a singleport into the 12's at 100+
Offline 1blk66
« Reply #17 on: June 22, 2006, 09:39:36 PM »
Well done James, looks awesome !!!
« Reply #18 on: June 22, 2006, 09:50:02 PM »
I'd like to say yes Kev but are you going to make it down this time????
Bring your wallet.
« Reply #19 on: June 22, 2006, 11:23:54 PM »
Being the drama queen that I am - video will be up after the show weekend - if you want to see it before come the the WCSD!
Offline LIQUID
« Reply #20 on: June 23, 2006, 01:26:01 AM »
lookin' good james
