Author Topic: 72 Bus Help  (Read 1068 times)
Offline jess rotten
72 Bus Help
« on: June 20, 2006, 10:27:09 PM »
went nuts and brought a hippy van two problems the motor wont start and the sliding door comes out of the track. Is there any place to buy used parts in B.C. and is there any repair shops in central bc I'm in quesnel.It has one wlid paint job.
72 Bus Help
« Reply #1 on: June 21, 2006, 06:10:38 AM »
Welcome to the VW ownership adventure.
I can't even begin to suggest why the motor won't start but remember the first rule; gas+air+compression+spark=fire. If you are missing one it won't work.
as for parts, start phoning around to wrecking yards in your reigon, you never know.
The door is probably falling out because the track on the rocker panel is rotted away. You'll need to weld in a replacement piece (big job) or lay a piece of new metal over the missing parts of the bottom track (mickey mouse but the door stays in and kinda rolls)
Good luck.
Offline LIQUID
72 Bus Help
« Reply #2 on: June 21, 2006, 12:11:43 PM »
is the door coming out of the track at the bottom? if so check the lower bracket that goes into the track at the bottom of the door. there should be a big bearing that goes into the track. if it isn't there or really loose that should be the problem.
dwane
