Author Topic: Couple Questions  (Read 1250 times)
Offline shovel80
Couple Questions
« on: June 19, 2006, 08:24:20 PM »
will this release bearing ??
match up with this pressure plate ??
the reason I am asking is that my old swing axle trans had the old release bearing
and How do you remove the weather stripping from the door jamb without wrecking it ??
Offline G-dog
Couple Questions
« Reply #1 on: June 20, 2006, 09:36:35 AM »
Don't know about the bearing,but if you take a putty knife and jam it between the pillar and the weather strip you can bend the tabs that hold it in towards the inside of the car ,you should be able to get 'er out..
Offline Rob DVKK
Couple Questions
« Reply #2 on: June 20, 2006, 10:06:00 AM »
As for the bearing, I'm pretty sure that collared input shafts like the one you have don't use the mating surface (the centre ring in the pressure plate). At least that is the way it worked with the older types of kennedy's
Couple Questions
« Reply #3 on: June 20, 2006, 10:07:01 PM »
Rob is right.  The trans is 71 and later, your clutch is 70 and older.  To use that pressure plate, take it off and remove the center ring thing.  There should be some kind of sheet metal clip holding it in place.
Offline shovel80
Couple Questions
« Reply #4 on: June 20, 2006, 11:02:42 PM »
Thanks Guys got the weather striping figured out will work on the clutch when it is time to put it all back together
Dave
