Author Topic: Redrilling Rotors/drums  (Read 1083 times)
Offline Aircooled Angel
    • http://www.kaferkraft.ca
« on: June 18, 2006, 09:04:34 PM »
Hi guys.
Just wondering if anyone has any experience with redrilling a stock ghia disc and a 4 bolt rear drum to a porsche  pattern?  is there enough material to do this safely?  Wanted to buy  blanks or the discs/drums that come already drilled but no one seems to have any in stock.  Also on a link pin disc brake drop spindle, I assume they take the later style bearings? thanks
Mike
« Reply #1 on: June 18, 2006, 09:19:02 PM »
Mike,
I have had many sets done, Mine have been on the car since 1994 and no problems. The stock 4x100 drums and rotors work fine when going to the 5x130 as they re use one orig hole. If you want blank rear drums I have some in stock. We can also get all your drums/rotors re drilled for you if you like.
G.
Offline Dan
  • Crown Royal straight up....Thanks
« Reply #2 on: June 19, 2006, 04:00:48 AM »
..What is it worth too have drums and rotors done ..How long does it take ????
We are Bigfun
Offline G-dog
« Reply #3 on: June 19, 2006, 01:20:08 PM »
I have a new, unused set of rear drums complete with new shoes &cylinders drilled for porsche 5 I'm not using ,Call me at Airspeed if you are interested.Gary.
« Last Edit: June 19, 2006, 01:21:14 PM by G-dog »
