Author Topic: Tranny Question  (Read 6279 times)
Tranny Question
« on: June 15, 2006, 03:51:14 PM »
Tranny code AS28063  bolt nosecone??? Every see one of these, and good parts out of them?
Tranny Question
« Reply #1 on: June 15, 2006, 11:51:01 PM »
Not yet.
The list says 3.88 R&P.  The code says it was made on June 28, 1973.  It's a SSC, right?  If so, it has a 9 tooth mainshaft, 15 tooth side gears in the diff, likely a steel 1-2 fork.
Tranny Question
« Reply #2 on: June 16, 2006, 01:33:31 PM »
dude you rock!!!
The thing that threw me was the 3 bolt nose cone
Cheers thanks
Tranny Question
« Reply #3 on: June 17, 2006, 01:23:24 PM »
Is it a swing axle or IRS?  If IRS, SSC or DSC?
Tranny Question
« Reply #4 on: June 17, 2006, 10:22:12 PM »
Swing, DSC, three bolt front nose
Tranny Question
« Reply #5 on: June 18, 2006, 12:58:17 PM »
Hang onto that one.  That is the perfect core to build the ultimate swing axle gearbox.
Guided late TO bearing
90mm long clutch arm
Late larger pinion bearing
15 tooth side gears
9 tooth splined mainshaft
O-Ring'd side covers
Likely a steel 1-2 shift fork
I was at Darren's place yesterday and saw a late swing gearbox he had.  It was the same as yours, but the code, AY, is a 4.12 R&P.
Tranny Question
« Reply #6 on: June 18, 2006, 07:56:36 PM »
Cool............Hey Bruce ya feel like building a tranny?????
Tranny Question
« Reply #7 on: June 20, 2006, 10:19:44 PM »
What are you looking for, stock rebuild or something that can take some abuse?
Tranny Question
« Reply #8 on: June 22, 2006, 07:37:11 PM »
abuse................
Tranny Question
« Reply #9 on: June 22, 2006, 08:58:17 PM »
Cuanto?
