Author Topic: General Questions,  (Read 4289 times)
General Questions,
« on: June 15, 2006, 06:11:07 AM »
1- Can I identify the size of the flywheels by looking at the Starter numbers? i.e. 200mm vs 180mm?
2-The 66 has a 1300, 12V coil so, I am assuming starter and flywheel are 12V too.
3- Is there any differences between 12V and 6V transmisions, other than the starter?
More later
« Last Edit: June 15, 2006, 06:13:18 AM by egspot »
Offline Cameron
General Questions,
« Reply #1 on: June 15, 2006, 08:15:06 AM »
1: no
2: maybe
3: yes
General Questions,
« Reply #2 on: June 15, 2006, 09:23:58 AM »
1: no
2: maybe
3: yes
#3, What about it? Could you expand on the diff?
General Questions,
« Reply #3 on: June 15, 2006, 10:13:46 AM »
Bellhousing clearanced for larger flywheel, 12v starter bushing.
Some people still use the 6v starter on 12v, cranks real fast just don't do it for too long.
General Questions,
« Reply #4 on: June 15, 2006, 10:47:00 AM »
Thanks.
I quest that I will have to check the starters for some numbers that indicate whether they are 12 V or not.
Offline 68IIIbuggy
General Questions,
« Reply #5 on: June 15, 2006, 05:32:41 PM »
6v starter has larger shaft and gear. Difference is obvious, especially when compared side-by-side.
