Wheel & Tire Forum
Replacing Hubcap Clips On Wide 5's...
Topic: Replacing Hubcap Clips On Wide 5's... (Read 5613 times)
June 14, 2006, 09:34:12 PM »
anyone ever do it and have any tricks they want to pass on? are there replacement clips or should i just salvage one off the spare?
i'm thinking grind off or drill out the old and weld in the new. anything else to consider?
kirin
June 14, 2006, 10:17:44 PM »
Small panhead screws and nuts. So if they break again easy fix.
bwaz
June 20, 2006, 10:20:10 AM »
I've tried to hammer new official VW part rivets, but gave up after two of them. I didn't have the proper press to do it. I ending up using large rivets, which held nicely and didn't have to keep checking that the nut and bolt were still on.
Brian
June 21, 2006, 05:57:42 PM »
thanks for the replies you guys.
i went with the drill out the old and rivet in the new method. worked like a charm.
Wheel & Tire Forum
