Author Topic: What Is This?  (Read 6875 times)
What Is This?
« on: June 10, 2006, 10:20:13 PM »
All my previous VWs where in Puerto Rico and Hawaii. I have been under the time after time and I have never seen anything like this.
Tje only thing I would think would be a heater of some sort.
Offline neil68
What Is This?
« Reply #1 on: June 10, 2006, 11:19:37 PM »
Not DVKK...but that is indeed the gas heater installed by the factory on '67 & '68 Beetles...
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
What Is This?
« Reply #2 on: June 11, 2006, 02:44:14 AM »
VW called that a heater booster.  That version is junk.  Don't waste your time trying to get it to work.  Just throw it away.
What Is This?
« Reply #3 on: June 11, 2006, 11:05:12 AM »
Thanks, that will save me some time, weight, and space.
What Is This?
« Reply #4 on: June 11, 2006, 11:08:29 AM »
But i got a 66, or do I?
Any other places I should look for , to id the year/model?
Offline 68IIIbuggy
What Is This?
« Reply #5 on: June 11, 2006, 04:00:21 PM »
Emilio, My 66 bug has a gas heater like that, as did my 69 Ghia.
What Is This?
« Reply #6 on: June 11, 2006, 05:41:47 PM »
It's called a Webasto heater and I've seen them as early as 60.
What Is This?
« Reply #7 on: June 12, 2006, 03:01:20 AM »
When you get it out, clean off the ID tag.
I know that 65s sold in Canada had Eberspacher gas heaters, as did 69s.  And 67 & 68s got the heater booster like yours, but I wasn't sure about 66s.  Do you also have an extra indicator light drilled into the dash near the top of the speedo?
What Is This?
« Reply #8 on: June 12, 2006, 08:48:27 AM »
Hey Emilio,
if you're tossing it, I'll gladly take it, I need an extra push of my heat, and would be curious to see how it works. I had one of my previous 68's and the air flow seemed good. Let me know
Brian
What Is This?
« Reply #9 on: June 12, 2006, 02:02:07 PM »
Hey Emilio,
Brian
When I get it out and make a decision you are 1st in line.
« Last Edit: June 12, 2006, 02:02:41 PM by egspot »
What Is This?
« Reply #10 on: June 12, 2006, 09:28:59 PM »
thanks!
Brian
