Author Topic: Raising / Lowering Standard Beetle  (Read 1391 times)
Offline cyclingches
« on: June 09, 2006, 12:02:53 PM »
The rear of my bug is a bit saggy and I'd like to have the car level or slightly lower in the front.  Is there an easy way to drop the front just a little?  Or can I just replace the rear shocks?  What's my easiest option without having to crank up the rear torsion bars?
Thanks,
Ches
Offline Pipes
« Reply #1 on: June 09, 2006, 12:27:11 PM »
not the best way, but a cheap way is to pull some of the front Springs.
Right way would be to get an adjustable front beam.
 :rockon:
Trying for low, show & go
1967 Beetle
« Reply #2 on: June 09, 2006, 05:53:34 PM »
it sounds like the back end is the problem so i'd deal with that first. it's not that hard turning torsion bars.
if you want to lower the front after that get a beam with adjusters in it so you can dial in the desired height or install drop spindles.
i would advise against removing leaf springs from the front beam.
Offline steiner
« Reply #3 on: June 11, 2006, 09:26:41 PM »
Pull the leaf springs out! I did it! Temporary but hey it does the job and rides awsome!
1964 21 bus
Offline cyclingches
« Reply #4 on: June 12, 2006, 01:33:12 PM »
I was thinking about going the cheap route by pulling out some leaves but doesn't that mean I have to take everything apart??  I think I am going to go with the dropped spindles, do I need any specific tools or would a hammer do the trick?  Anybody has a set for drum brakes that they want to sell cheap?
