Author Topic: Stub Axle Removal  (Read 1076 times)
Stub Axle Removal
« on: June 06, 2006, 08:30:28 AM »
What's the trick to removing the stub axles from irs trailing arms? I've got the axle stripped down to trhe point I can see the bearing but can't seem to drive the axle out. Am I missing a C-clip or something? Thanks.
Jeremy
Offline Bullyboy
Stub Axle Removal
« Reply #1 on: June 06, 2006, 04:34:35 PM »
I have a big princess auto bearing puller for that job.
The bearings and the inner sleeve sometimes get stuck to the shaft so the shaft has to be pushed thru.
If your changing the bearings after, remember there is a big snap ring next to the ball bearing on the CV joint side.
Stub Axle Removal
« Reply #2 on: June 06, 2006, 05:08:12 PM »
I got it. Just used a bigger hammer.
