Author Topic: Pix Of Both My Rides  (Read 9532 times)
Offline volksnut
« on: June 01, 2006, 05:54:42 PM »
Well the front of the bus is lowered , next is the back....but how much? 1 or 2 splines..
« Reply #1 on: June 01, 2006, 06:10:03 PM »
start with 1 outer spline, tough part about doing it is that you have to put it all back together to see how it looks, dont forget to clearance your spring plates and to go with a smaller shock in the rear, otherwise you get to listen to clunking all the time.
Offline volksnut
« Reply #2 on: June 01, 2006, 06:46:40 PM »
what cha mean clearance the spring plates :blink: ??? For tire clearance or shock? These buses are new to me :unsure: oh yeah, what about the snubber, use a beetle and what shocks are you using???
« Last Edit: June 01, 2006, 06:50:21 PM by volksnut »
« Reply #3 on: June 02, 2006, 09:00:48 AM »
You have to notch your spring plates where they come into contact with the stop.
Offline Needles
« Reply #4 on: June 02, 2006, 09:24:25 PM »
WTF? Don't DICK around, slam it, ( lowered plates..uh  100.00-Airspeed)you know thats what you want to do. Cut the snubbers off....
What size rims are those?
Drag those mud flaps!!
http://www.airspeedparts.com/photogallery/...?album=6&pos=16
http://www.airspeedparts.com/photogallery/...?album=6&pos=12
If you weigh under 200lbs, take off the sway bar too.. ;) or have it removed by...
uhhhh..by the way thats BUGSMELL's  72 :ph34r:
« Last Edit: June 02, 2006, 09:25:30 PM by Needles »
Offline ArsenicPants
« Reply #5 on: June 03, 2006, 01:00:43 AM »
pretty sure i saw your bug downtown today
i walked past it on Robson around 1 PM, with baby gas burners, right?
pretty slick ride :D
couldn't stop staring as i walked by
« Last Edit: June 03, 2006, 01:02:24 AM by ArsenicPants »
Original SBC Member #16
« Reply #6 on: June 03, 2006, 09:53:49 AM »
sounds like tom rivers car actually....
« Reply #7 on: June 03, 2006, 12:13:00 PM »
Yes definitely remove the sway bar if your going to go any lower, it will drag and snag, and as Needles experienced it can do much worse.
Offline volksnut
« Reply #8 on: June 04, 2006, 04:23:12 PM »
Needles.....their 16x7 with a 45 ET
