Author Topic: My Bay Finally Gets Lowered  (Read 6297 times)
Offline volksnut
« on: May 29, 2006, 03:33:41 PM »
This is before...oh thats high!
next I got it on the ground today...few more things to do, but man I like it....Lowered beam, disc brakes, 16x7 Ronals with 205/45-15
I used 67mm 911 studs (thanks Geoff) and 10mm spacers....
Offline surgerypending
« Reply #1 on: May 29, 2006, 05:23:29 PM »
Sweet! :rockon:
« Reply #2 on: May 29, 2006, 07:45:32 PM »
Nice!!! Love your bus, It looks so much better down low. :rockon:
Offline LIQUID
« Reply #3 on: May 30, 2006, 01:01:50 AM »
looks awesome.
dwane
« Reply #4 on: May 30, 2006, 08:26:21 AM »
Damn that looks good :rockon:  :D
Offline ArsenicPants
« Reply #5 on: May 31, 2006, 10:00:08 PM »
looks great, but comon'.... you can go lower ;)
diggin' the rims
Original SBC Member #16
Offline Matt Davis
    • http://www.mattdavisracing.com
« Reply #6 on: June 11, 2006, 10:02:07 PM »
How did you lower it? I'm trying to find floors and I found the bus boys adjusters that I'll TIG into my beam, but how did you do the rear? Just readjust it?
Thanks!!
Offline volksnut
« Reply #7 on: June 12, 2006, 07:48:39 PM »
Hey Matt fellow turbo dude!  I used adjusters (Avis style) CB carries them now $24.95 each....you either have to drill out the peens that hold the center anchor or twist them loose the Bus Boys method then weld in the adjuster....I guess mines lowered 4\" front, I used Audi 16x7 wheels and 205/45-15 front, I used the 68 beam but changed out the spindles to 71 up and used stock discs with 5x112 bolt pattern (same as the Audi) it stops great even with no power brakes.....I haven't lowered the rear yet....but I hear clearanced spring plates and 1 outer notch will do it.....have fun and post pictures of your progress....
« Last Edit: June 12, 2006, 07:50:58 PM by volksnut »
Offline Matt Davis
« Reply #8 on: June 13, 2006, 12:23:43 AM »
Hey Volksnut!! Thanks for the reply, the CB adjuster is for a bus beam or are you adapting it for use on a bus and it's a Type 1 adjuster?
Offline volksnut
« Reply #9 on: June 13, 2006, 01:34:58 PM »
Offline Matt Davis
« Reply #10 on: June 13, 2006, 01:39:07 PM »
lol i went afterwards and said \"hey dummy, why don't you just look for it\" lol
Thanks man!!
How much lower can you go with your beam? It looks great!
Offline volksnut
« Reply #11 on: June 13, 2006, 08:15:39 PM »
it's set at half way...I would think it could go a few more inches, it rides great like it is and doesn't rub ...the snubber mount is cut off so it can go low, but I'm thinking of running some shorter shocks for more travel, their the same as a link pin
Offline Matt Davis
« Reply #12 on: June 13, 2006, 08:31:11 PM »
Looks great! Can't wait to see it all done! :rockon:
