Author Topic: Getting The Glass Out Of Ventwindow Frame  (Read 5172 times)
« on: May 26, 2006, 12:29:06 PM »
Hey guys,
Trying to get the glass out of the vent window frame so I can get it rechromed and put in a new seal and put the glass through the dish washer. Any advice on how to do that?
« Reply #1 on: May 26, 2006, 12:37:20 PM »
Hardwood stick and a hammer, lay the window on a towel or piece of rug, lean on it and tap tap tap the frame off it with the edge of the stick. work evenly and on both sides so you don't bend the frame.
Steel wool works very well for cleaning glass but NEVER use scotchbrite.
« Reply #2 on: May 26, 2006, 05:08:28 PM »
i just pulled,held the frame and the pulled the glass
« Reply #3 on: May 26, 2006, 09:55:46 PM »
Ballpeen hammer, use the rounded end and hit the window once
Offline rustybus
« Reply #4 on: May 27, 2006, 09:04:56 PM »
I wouldn't know the glass in mine keeps falling out. I would try the Hulks idea it would be the quickest :D
« Reply #5 on: May 28, 2006, 09:34:58 PM »
I think the Hulks preferred method(and probably mine) Will be to pay someone to do it :P
« Reply #6 on: May 29, 2006, 06:12:05 AM »
What is it that you are trying to do? Are you trying to get the glass out of the door?
I had a problem with mine, it would not come back up. Taken care off it.
I may be able to help.
call me.
« Reply #7 on: May 31, 2006, 11:25:56 PM »
Trying to get the glass out of the chrome frame that flips open...
« Reply #8 on: June 01, 2006, 12:26:28 PM »
are the frames out?
i don't want to hear another word until you have atlest tried to pull on them :!:  :D
« Reply #9 on: June 04, 2006, 11:35:32 PM »
Frames are out of the car. I will start doing a bit of tapping and see what happens with the sunbaked rubber and the glass. I know for sure one of the windows has been replaced(Shocking) will be nice to have some matching glass.
Offline suburbiana
    • watershed photography
« Reply #10 on: June 09, 2006, 07:38:50 AM »
Kirin, there is quite a section on that in the Benley manual - one word of caution, though - once the glass is out it is a huge pain in the arse getting the glass onto the seal and fitted back into the vent frame, the old shops actually used a press jig to get it snugged in there.
Also see the articles at www.thebugshop.org as he explains many of these procedures (how to do and not to do ...)
Craig
'66 Seasand Bug - SOLD Feb '07
« Reply #11 on: June 09, 2006, 11:57:42 AM »
Hey I realize this.
But I'm doing a complete resto and I think the results would be a bit underwhelming if I didn't at least fix the seals..
