Author Topic: Engine Idle Speed  (Read 5290 times)
Offline flat4
Engine Idle Speed
« on: May 15, 2006, 08:45:27 AM »
How drastically should idle speed change with/without the fan belt?  I run a CB serpentine belt, broke it at the track this weekend, and my idle speed jumped up to about 3000 rpm.  Is this normal?  If so, seems like it would be a huge HP killer.  Thoughts?  Advice?
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Engine Idle Speed
« Reply #1 on: May 15, 2006, 08:49:52 AM »
I wouldn't think you would pick up much rpm (maybe a few hundred at most) with a broken fanbelt, did something take a kit by the broken belt?
Engine Idle Speed
« Reply #2 on: May 15, 2006, 09:37:19 AM »
Im no mechanic but anytime I have pulled my fan belt off before racing I havnt noticed a difference at all. You should leave it off anyways for racing. Good luck, Brian
Offline flat4
Engine Idle Speed
« Reply #3 on: May 15, 2006, 10:07:04 AM »
Take a kit?  Huh?  Well, besides the shards of rubber and a clogged jet from the rubber (I wasn't running cleaners) I don't think so.  The belt was hanging on the alt pulley.  I don't think it went anywhere.   As soon as the new belt was installed, the idle returned to normal (my normal) again.  Very odd indeed.  I was too afraid to run at the track without a belt.
Water is for ducks
Sand Rail Project
Engine Idle Speed
« Reply #4 on: May 15, 2006, 01:04:20 PM »
I meant to say take a hit :)
Offline flat4
Engine Idle Speed
« Reply #5 on: May 15, 2006, 02:49:14 PM »
My car is not on drugs, creep.
Water is for ducks
Sand Rail Project
Engine Idle Speed
« Reply #6 on: May 16, 2006, 05:17:45 PM »
No,... but maybe you are Fred; if you're saying your idle is gaining that much! :P
Engine Idle Speed
« Reply #7 on: May 16, 2006, 07:45:19 PM »
why??
i would rather run without the belt, rather than explode a fan...
Offline flat4
Engine Idle Speed
« Reply #8 on: May 17, 2006, 02:33:07 AM »
I guess I have faith in welded fans.  Things at the track here are different, as on Secret Street nights, it's all hot lapping. Perhaps I'll make a few runs sans belt and see what happens. I know it sounds like a crazy issue,but I wouldn't have believed it if I didn't see it for myself.  I'll be checking it tomorrow or Thursday in preparation for Friday.
Water is for ducks
Sand Rail Project
