Author Topic: Engle 125 Cam  (Read 8443 times)
Offline bufferman
Engle 125 Cam
« on: January 04, 2004, 09:52:41 PM »
has any one had any experence with this cam and if so how did they like it,,,,have a 1776 with 40x35 ported and polished heads and was wondering what carbs to run have a set of 42 dcnf  44 idf and 48 ida going to be in a driver
you not worth having if u cant drive it and enjoy it
thanks
steve
Engle 125 Cam
« Reply #1 on: January 05, 2004, 01:25:02 AM »
I ran a W-125 for just over 60k miles, but in a larger engine.  I wouldn't recommend it for a 1776.  Instead I think you'd be better off with a W-120.  Its not that much smaller than a 125, but will give better reliability.  The 125 will be a lot harder on valve train components because its much more agressive, and in a 1776 you will really have to wind it high to get any power out of it.  That cam would make good power to 7500 or more, but valve train doesn't last when you are winding it that high.  The 120 will still make good power to 7k.
If you are going to drive it daily, then I recommend 40IDFs or the 42s.  A 44 will work, but a 40 will give you way better bottom end torque.  Forget the IDAs until you have a bigger engine.  I put IDAs on my current 2 liter for a couple of months last summer and was glad to have the 40 Dellortos back on it in the fall.  The gain in top end hp wasn't worth the loss in bottom end drivability/torque.
