Author Topic: Cases  (Read 3948 times)
Offline bufferman
Cases
« on: May 08, 2006, 09:32:52 PM »
need to buy a case what is the good and bad with the new cases alum. and the mag.anyone have any experences with the alum rased roof case
thanks steve
Cases
« Reply #1 on: May 09, 2006, 09:40:45 AM »
Some of the new generation High roof cases had a issue with not having a breather hole cut inside the case. We check and mod all our cases to make sure they are correct.
The alum case will run a little hotter than the mag case but it's much stronger.
Both are in stock.
Offline bufferman
Cases
« Reply #2 on: May 09, 2006, 09:42:56 PM »
thanks geoff from what i can see same price also by the time you geteverything done to the mag case by hotter you mean oil temp or overall
thanks  steve
Cases
« Reply #3 on: May 10, 2006, 09:27:44 AM »
Yes, oil temp will be a little higher as the Alum will retain more heat. What size engine were you looking at building? PM me and I'll see what I can do.
