Author Topic: Are Pans And Body Interchangeable?  (Read 3129 times)
« on: May 08, 2006, 11:07:57 AM »
Would a 64 t1 pan takes a 66 or 72 body?
how about 66 pan with 72 body?
« Reply #1 on: May 08, 2006, 11:39:16 AM »
In 1969 the rear body mount in the rear fenderwell was moved up, You can swap all body/pans with no mods upto 1968. To put a later body on a early pan you will just need to make a spacer for the rear mount. If you put a early body on a late pan you would need to move the mount up (requires welding)
