Author Topic: Current Thru Ignition Switch?  (Read 4325 times)
Offline blarneyman
« on: May 02, 2006, 09:34:25 PM »
Does anyone know what kind of current goes through the ignition switch on a 73 beetle when starting? 10A, 20A, 30A? Wire size I'd say 30A.
www.mbvv.org
My \"new\" 1970 Ghia
Offline AlanU
« Reply #1 on: May 02, 2006, 10:19:58 PM »
to eliminate the higher current to drive the solenoid at the starter just install a bosch relay
30  -  12volt constant
87  -  Starter solenoid
85  -  Trigger (from ignition switch)
86  -  ground
That'll increase the life of the ignition switch behind the tumbler.
« Reply #2 on: May 03, 2006, 12:03:09 AM »
I doubt it's 30A since you are only powering the solenoid, not the windings of the starter motor.
Offline blarneyman
« Reply #3 on: May 03, 2006, 06:51:44 AM »
The ignition switch is already shot. That is why the question came up. I'm looking at (at least temporarilly) installing a push button under the dash. The PO had aready hacked the wiring so it wouldn't be much worse than what is already there.
www.mbvv.org
