Author Topic: Ignition Problems  (Read 3928 times)
Offline 68 vert
  • Junior Member
Ignition Problems
« on: April 30, 2006, 09:28:08 PM »
I have a 2165cc motor with a new altenator and electronic points, the problem that I am having is that My car is hard to start and if I take off the lead wire from the ignition coil to the distributer and hold it 1/2 inch away it fires right up could you please help make since of it. thanks
Ignition Problems
« Reply #1 on: May 01, 2006, 02:48:36 AM »
Are you sure you got the wires connected to the coil correctly?
Offline 68 vert
  • Junior Member
Ignition Problems
« Reply #2 on: May 01, 2006, 05:20:11 PM »
I believe so. I got a diagram off the internet on how to wire in an altenator and I believe that it showed all that all though i dont have that anymore.
