Author Topic: Eng Turned Sheetmetal  (Read 1600 times)
Offline nivag
  • Gavin Lee
« on: April 20, 2006, 03:48:28 PM »
Anyone know where I can source a small piece of engine turned sheet metal? Need a piece about 15\" wide and 6\" tall.
Thx, Gavin
« Reply #1 on: April 20, 2006, 03:56:44 PM »
Got a drill press? You can do it yourself. I don't know of anyone who sells it pre done besides the stuff Mirko used to get but it wasn't metal.
Offline nivag
  • Gavin Lee
« Reply #2 on: April 20, 2006, 04:18:24 PM »
Did it before and messed up and took forever. Used a drill press and cork... Was hoping ther was some pre fab stuff around. If not I may just use thicker alum. Need to make a gueage panel for the buggy.
« Reply #3 on: April 20, 2006, 04:42:18 PM »
I will ask my machine shop tmrw and see what they say - what gauge metal?
« Reply #4 on: April 20, 2006, 04:58:46 PM »
The champagne cork and valve grinding compound is the traditional way but I've seen it done with a wire cup wheel if you have a hard alloy. I've used a plywood disc with firm sponge and leather glued to it for big swirls.
You can use a yard stick like piece of wood with notches cut into it for a guide if you don't have a drill press or are doing something that won't fit in one, clamp it to the part with shims under it and sit the mandrel shaft of your drill in a notch, don't forget to shift it a half notch over for the next row down.
Offline Tom H.
« Reply #5 on: April 20, 2006, 05:43:18 PM »
well, there goes the neighborhood. another split with engine turning?
 :angry:
Eastwood sells panels pre-turned plus they have the Craytex roll on a mandrel for doing it yourself.  I think maybe Speedway Motors also sell some. The Craytex works very well and is quick. Craytex is like valve grinding compound in a \"erasure\" like rubber matrix, just use something like a light oil for a lube.
Offline nivag
  • Gavin Lee
« Reply #6 on: April 20, 2006, 05:44:03 PM »
Hey James, nothing too thick. Just stiff enough to mount some guages in... maybe 18 guage?
« Reply #7 on: April 20, 2006, 06:50:45 PM »
sweet. metal flake paint job and an engine turned sheet metal gauge panel. with the sun shining that buggy is going to be like a rolling tanning bed.  ;)
i'm going to start putting on the spf30 and call dibs on shotgun for a cruise.
you are going to have one hell of a fun summer driving that car gavin. B)
Offline Tom H.
« Reply #8 on: April 20, 2006, 08:05:08 PM »
the buggy?
wadda need gauges on a baby buggy for?
 :rockon:
Offline nivag
  • Gavin Lee
« Reply #9 on: April 20, 2006, 08:47:07 PM »
Tommy...  I like to see when the needle comes back around to the 0 on the speedo... call me old fashioned.
Offline Tom H.
« Reply #10 on: April 21, 2006, 06:33:39 AM »
yeah, I hear ya. I haven't hooked mine up yet, afraid to knock the post out of the speedo  ;)
 :rockon:
