Author Topic: External Oil Coolers  (Read 4631 times)
Offline captCRUNCH
« on: March 29, 2006, 03:12:09 PM »
where do you mount yours? any pics? thanks guys.
Offline Bloke
    • http://www.cardomain.com/profile/blokeswagen
« Reply #1 on: March 29, 2006, 03:35:26 PM »
I don't have any pics sorry, but I have the 11\"x11\" Mesa, with a 12\" Spal fan in my 62.  I mounted it above the trans, under the rear parcel area.  It is off to the driver's side and I put some small spacers (about 1/2\") above it so the air could get in around it.  It's a tight squeeze over the bowden tube, but it fits.
Rob
Rob
The guy over in Thunder Bay.
1962 Cal-Look Bug
1975 project Bug
« Reply #2 on: March 29, 2006, 05:31:37 PM »
Its there on the left side, can you see it?
« Reply #3 on: March 29, 2006, 06:08:08 PM »
Not to highjack,
very interesting, Keep it coming guys. We all need to know about this.
egspot
Offline Swartz
« Reply #4 on: March 29, 2006, 08:45:34 PM »
chris,
Is there anything between the ground and your cooler? How did you mount it? Im probably going to have to find a new place for mine when i install that drag bar i got off of you.
Everything takes time
« Reply #5 on: March 29, 2006, 09:21:33 PM »
its mounted to the torsion tube housing using some hose clamps I then made a bracket to attach to the tranny horns.
« Reply #6 on: March 30, 2006, 09:04:45 AM »
Craig, when you come in today I'll show you a few in the cars here at the shop.
Offline flat4
« Reply #7 on: April 03, 2006, 12:06:50 PM »
Mine is mounted directly to the parcel tray, directly above the transmission.  I used spacers underneath the mounting surface to increase the gap between the cooler and the tray itself.
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
