Author Topic: No Fuel In Filter - Help Im New To These  (Read 7116 times)
Offline tanman
« on: March 26, 2006, 05:07:18 PM »
hey, my car is having troubles. i was able to run it a few times, i just got it on the road. now it wont start and i noticed that the little fuel filter has no fuel in it, even after i turn the engine over and pump the gas. do i need a new fuel pump? how do i check? thanks
tanner
« Reply #1 on: March 26, 2006, 05:38:09 PM »
mechanical or electric pump?
Offline tanman
« Reply #2 on: March 26, 2006, 05:57:25 PM »
im pretty sure its not electric... its a 67, and my official manual says nothing about anything electrical on it
tanner
« Reply #3 on: March 26, 2006, 06:02:44 PM »
one side of the fuel filter goes to the carbs and then the other does it go down to a part on the motor?
Offline tanman
« Reply #4 on: March 26, 2006, 06:04:06 PM »
yes exactly. and it was running earlier today, but really rough when i slowed down, and now that little filter is bone dry
tanner
« Reply #5 on: March 26, 2006, 06:10:19 PM »
well your fuel pump may be pooched, but you may also have debris in the fuel line or tank, is there a fuel filter under the gas tank? There may be a screen in the bottom of the tank but you will have to drain the tank and remove it to clean the screen
Offline tanman
« Reply #6 on: March 26, 2006, 06:11:51 PM »
ok, i'll check to see if there is fuel coming from the tank, if not i'll drain it and clean that. if there is, i should replace the pump?
tanner
« Reply #7 on: March 26, 2006, 06:14:31 PM »
you can disconnect the line going from the gas tank to the pump and see if there is fuel present, if so it may just be a bad pump.
Offline tanman
« Reply #8 on: March 26, 2006, 06:15:33 PM »
ok i'll give that a shot. i'll have to drive over to where it stopped before it gets to dark tonight, figure out if i need to order a pump tommorrow!
tanner
Offline tanman
« Reply #9 on: March 26, 2006, 06:16:53 PM »
dude, your in cloverdale? maybe someday if you have some time off i could pay you to come give it a look... im right at fraser hwy and 188th... pretty close. -if thats something your into
tanner
« Reply #10 on: March 26, 2006, 06:28:58 PM »
well i could probably find time to take a look...
Offline tanman
« Reply #11 on: March 26, 2006, 06:29:49 PM »
whenever you could, 604-616-0015. cause i know its got a few things going on, and im real new to these and want to learn. but i dont have anyone i know to teach!
tanner
Offline tanman
« Reply #12 on: March 26, 2006, 07:46:35 PM »
ok 76BUS... i checked the gas line into the pump, plenty of gas coming in there. i took off the line from the pump to the carb and blew and sucked, trying to do something... no dice. still wouldnt start and if i sucked on the line to the carb, i couldnt get gas. finally i put some gas directly into the carb, and the car started right up. i drove it home, and when i got home i checked, still not much fuel in that lil filter. barely any actually. i tried to start it up again but it wouldnt. is my pump faulty?
thanks
tanner
« Reply #13 on: March 26, 2006, 07:55:17 PM »
I would have to say that you may have a faulty pump and I am sure someone on here has one if not Airspeed can get one!
Offline tanman
« Reply #14 on: March 26, 2006, 08:15:10 PM »
i'll put one on tommorrow. and i'll let you know what happens. thanks for all your help i appriciate it. anytime you want to come poke around and teach me, i'll buy the beers. ;)
tanner
