Air Speed Lounge
Original Color Engine Block Type 1-1200cc Engine
Topic: Original Color Engine Block Type 1-1200cc Engine (Read 1575 times)
vwshawn
March 13, 2006, 03:40:26 PM »
Does anyone know the color code for the engine block paint for a 1965 Beetle, 1200cc 40HP Motor.
Please respond ASAP with advice.
Thanks,
Shawn
Geoff
March 13, 2006, 03:47:13 PM »
None, just pure mag
BUSDADDY
March 13, 2006, 05:19:25 PM »
Original bare metal may have a slightly brownish golden tinge due to the chromic acid pickling process used to keep naked mag from disintigrating from the moisture in the air. Depends on the alloy used in the case. VW Canada rebuilds were painted gold, sorry don't know the code.
March 13, 2006, 06:03:24 PM »
there is some controversy over whether or not it's a good thing to paint your acvw engine. some paints have a harder time dissipating heat than others. so if you're hell bent on painting your block, i'd look into that.
besides, the mag look is cool.
steveo_32
Gonna'own em all one day!
Waz up
March 14, 2006, 07:41:17 PM »
I have a mag acid dip at work makes the case turn slighly bronze, If the motor is not assembled i can dip it for you. (NOTE: must wash off otherwise eats at case it left on)
Last Edit: March 14, 2006, 07:41:36 PM by steveo_32
Lanny
March 14, 2006, 07:48:56 PM »
They were coated with Dow(cosmoline).
Air Speed Lounge
