Author Topic: Brake Equlizer Needed  (Read 6995 times)
« on: March 12, 2006, 09:37:56 AM »
first off i am running a Cb performance front disk brake kit and type 3 rear drums.
i am just getting around to start finishing the braking system and have heard of people having to put a pressure equlizer in.
i don't even know if i am calling it the right thing.something that will control how much brake pressure goes to the front or the back.
is this needed with the set-up i'm running or will i be fine with out it
thanks for any help
russ
« Reply #1 on: March 12, 2006, 10:21:08 AM »
It's fine without it.
« Reply #2 on: March 12, 2006, 01:25:49 PM »
Russ if you are doing that I would really suggest you try and run the widest front tires possible. That way you can maximize the most of your grip.
« Reply #3 on: March 12, 2006, 03:17:32 PM »
You don't need a proportioning valve, you don't need residual pressure valves, or any other pressure altering device.
« Reply #4 on: March 12, 2006, 03:37:45 PM »
thats the word i was looking for.
thanks guys
