Author Topic: Porsche Wheel Fit  (Read 7796 times)
Offline Bullyboy
Porsche Wheel Fit
« on: March 06, 2006, 10:37:53 AM »
Anyone running porsche wheels 7j x 15/52.3mm offset with stock front fenders?
I have a 2\" narrowed IRS beam with no brakes as yet.
Just wondering what people are running with theirs?
Thanks Mark
Porsche Wheel Fit
« Reply #1 on: March 06, 2006, 10:57:35 AM »
I'm not sure about the 15x7 but Jag (Buddy Guy) is running 16x7 all the way around on his 75 STD beetle with a 3\" beam.
Porsche Wheel Fit
« Reply #2 on: March 19, 2006, 10:15:11 AM »
they work great , i had to narrow my beam 3'' , AND drill my drums to make them fit ,(the adaptors that were on there still made them stick out  half an inch) ,.... i think i still after all that bent the lip on thw finders because it was really close.
don't get your drums drilled from C.I.P.  , not mentioning any names , but the owner was a dick when i was getting my drums drilled , took them 7 months !!!!....
fak you C.I.P !!!
Offline Bullyboy
Porsche Wheel Fit
« Reply #3 on: March 19, 2006, 02:00:30 PM »
I'll probably be running my early 944 N/A single pot disc brakes.
Machine work by vdubengineering.com
I am working on getting the rear arms and discs as well  B)
Only trouble is I can't run drop spindles with the 944 fronts.
So I have to be a little more conservative with the front drop.
Are you running the 52mm offset Budy?
Porsche Wheel Fit
« Reply #4 on: March 19, 2006, 08:43:30 PM »
yes , i talked to geoff , and we have the same offset.
if your disk brake kit wont offset your rim/tires you should have no problem. but thats with a 3'' narrowed beam.
« Last Edit: March 19, 2006, 08:58:57 PM by budy guy ! »
Porsche Wheel Fit
« Reply #5 on: March 20, 2006, 08:52:59 AM »
with stock front drums, trying to put fuch's on the beetle, is drilling the only way to get them under the front fenders? Would 4 1/2 or 5 1/2 wheels be better... 14's or 15's and then adapters on the back? I know lots of questions, just don't want to buy some wheels that won't work.
thanks
Brian
Porsche Wheel Fit
« Reply #6 on: March 20, 2006, 10:13:03 AM »
Brian,
I'm not sure if your offset is the same as Jag's. I run 15x5.5 on the front of my 59 beetle with droped spindles. I had 15x6 before with a 2\" narrowed beam. The wheels would have fit without the narrowed beam if I didn't use the droped spindles as the spindles will add 3/4 inch to the track.
Drilling the drums/ rotors is the best way to go as it will not add any offset, adapters will work in some cases without any problem.  Keep in mind most adapters will add 3/4\" or more.
G.
Offline Bullyboy
Porsche Wheel Fit
« Reply #7 on: March 20, 2006, 10:29:04 AM »
There is a tech article on vdubengineerings website too.
http://www.vdubengineering.com/technical/wheel.htm
Porsche Wheel Fit
« Reply #8 on: March 20, 2006, 11:14:20 AM »
thanks Geoff
what size tire on the front with the 5 1/2 rim? I think I can live with a spacer at the rear to fill out the back a little more, just concerned about getting a normal turning radius, and not crunching the fender every time I turn. (was it a 14 or 15 rim you use)
