Author Topic: 67 Wiring Problems  (Read 5349 times)
Offline tanman
67 Wiring Problems
« on: February 26, 2006, 01:57:59 PM »
hey i posted before but im still having problems. my left and right signal flashers are not working. the emergency flashers, however, will work (both left and right - front and back, everything flashes). i've checked all the wiring to see if it is correct. i have replaced the flaher box. i've checked and double checked the wiring into the flasher box, but i still cannot get the signal lights to work. when i test the flasher with a grounded test light, should there be power from 49a going into the steering column all the time? everything is connected properly and the lights go off when i pull the emergency flasher switch, but my signal lights just wont work. its getting pretty frustrating, i would really appriciate help. thanks!
tanner
67 Wiring Problems
« Reply #1 on: February 26, 2006, 02:09:23 PM »
have you tested the switch itself?
Offline tanman
67 Wiring Problems
« Reply #2 on: February 26, 2006, 02:24:04 PM »
i think i have, but how would i test that switch? (are you talking about the signal switch, in the steering column?)
tanner
67 Wiring Problems
« Reply #3 on: February 26, 2006, 02:25:27 PM »
yes, just a simple continuity test, make sure that when you switch it on that there is a circuit.
Offline tanman
67 Wiring Problems
« Reply #4 on: February 26, 2006, 02:26:45 PM »
i'll go test right now. thanks man
tanner
Offline tanman
67 Wiring Problems
« Reply #5 on: February 26, 2006, 02:33:05 PM »
i dont think there is any power. im testing from 49a (wire that goes from flasher box into sterring column) to the black and white wire (going from the steering column into the left signals)... is this the correct test? thanks
tanner
Offline tanman
67 Wiring Problems
« Reply #6 on: February 26, 2006, 02:52:34 PM »
when i put power directly from 30 (from fuse box) to 49a (goes into steering column) and then i use the turn signals, there is power. but no flashing.
tanner
67 Wiring Problems
« Reply #7 on: February 26, 2006, 04:00:10 PM »
humm, did you try putting the flasher into that circuit?
« Last Edit: February 26, 2006, 04:07:13 PM by 1976BUS »
Offline tanman
67 Wiring Problems
« Reply #8 on: February 26, 2006, 04:31:57 PM »
49a is connected to the flasher and to the steering column.
tanner
